Installed these. High hopes. D30 is cool stuff.
Please let us know if you like these. Do you have issues with your hands going numb?
Some issue.. Not horrible, but sometimes significant with the wrong sweep bars and thin grips.
You should try push on odi longneck. A lock on grip is just never gonna be comfortable because lack of material imho . Installed with spray paint I never had one slip , even ripping wet dh laps .
Wasn’t 1,000° in the garage this morning so I finally got to put new fork decals on the SS.
I also went back to 34x18.
Was at 2:1 all season but do I really need to push on these rides? 34x18 is good enough to comfortably spin these days.
The D30s were a fail for me. The dread locks are the best I have tried.
I have tried this Longneck too and I still orefer the Dreadlock.
This was fun
Snapped my lever off at watanong this afternoon....First lever I have ever broken in all my years of mountain biking.
So I knew I had a couple old XT, SlX brakes in my pile of junk......I found an old XT front I had from like 2017. I got both levers off...but there was an issue
On the older spare lever I had, this area is thicker then the newer lever on my pivot...and thus it would not fit nicely.
So I got my file out and shaved about 0.75mm off the sides to get it down to the same thickness as the one i broke
the process of putting this back together is a bit of an ass pain...getting the spring back in, then the pin thru...took a little trial and error, but i got it....seems to work fine....Should hold me over until my new lever gets here.
