Please 🔥 the blackwall tire, replace with gumwall then repost.Dealt with a too Enduro tire setup and a too xc setup on the other wheelset so I changed it up. Also finally got the 2nd cushcore installed.
Stan's Flow CB7
Rear: Maxxis Rekon 29x2.4 (Cushcore)
Front: Maxxis DHR2 29X2.4
Roval Control
Rear: Specialized Fast Track 29x2.3 (Cushcore)
Front: Maxxis DHF 29X2.5
should be 2 solid all round options for everything I ride around NJ swapping options. Weight of the bike with the CB7's on them was 30.5 lbs.
😉 Great setup.
The cool guys run skinwall front and blackwall rear, just sayin'... 😉Please 🔥 the blackwall tire, replace with gumwall then repost.
I don’t understand the whole ride wrap thing. I’ve seen that crap start to yellow after a year. How much frame protection do you need? Not busting here. I’m genuinely curious. Do you remove it right before you sell it down the line? Won’t the paint that isn’t covered fade? I would think it’d be a huge pain to remove too.
Comes right off with a hairdryer. But I agree about the whole bike. Key spots, sure.I don’t understand the whole ride wrap thing. I’ve seen that crap start to yellow after a year. How much frame protection do you need? Not busting here. I’m genuinely curious. Do you remove it right before you sell it down the line? Won’t the paint that isn’t covered fade? I would think it’d be a huge pain to remove too.
took the whole thing apart since i have to replace the lower swingarm anyway, and decided it would be a good time to clean all the pivots and run new cable housings. The internal routing is NOT as bad as i have heard it to be, but swingarm was in WAY worse shape than i thought it was when i noticed the crack
