@Patrick
Alberto knot is slightly different and allitle bit stronger than the albright but the FG knot has been tested as stronger than both of them but its alot more complicated to tie. I use the alberto knot but fish mostly freshwater so not worth it to do the FG knot for braid to mono or braid to fluro connections. As far as connecting to any terminal tackle I personaly like the palomar knot. Very easy to tie in mono, braid and fluro plenty strong enough for most applications.
This 100% Alberto and Palomar cover most of it. Double uni works good too. FG is way too complicated for me but I know it's effective.@Patrick
You can usually use whatever (reasonable)fishing knot yiu want with straight braid as long as you add 2 half hitches on top of it. Braid to mono.... albright....but I'll usually add a drop of super glue if its heavy mono on a trolling rig that doesn't have the mono changed off a lot.Well dang - @w_b showed me the way of the braid for heavier fish. Grabbed some 30lb test and started messing with some knots.
The ones i know pulled right out! not enough line friction. So sent a txt to Warren and @jklett to see how they roll.
learned about uni/modified uni for terminal tackle. looking at tying in the leader i remembered the albright from scouts for dissimilar
diameters that you never need to untie. Could also do some sort of double modified uni - but the albright is holding tight. Braid wrapped around the fluoro.
i saw a modified albright that put a few loops inside the the mono too.
whatcha got?
I use the FG. There’a good tutorials on SaltStrong that show how to keep tension on the line and get the wraps you need.
The fast and easy way to tie braid to mono is with a micro swivel. Check out spro power swivels. Size 8 is really small and good to at least 50 lb I think size 10 even smaller and good till 35saw this - and while it makes sense, it is a scary knot!!!
just make the braid bite into the mono!
hard to believe the half hitch at the end doesn't create a bend that iweakens the system, but apparently knot 😉
Good advice here. Quality matters with swivels, and spro makes nice stuff. If rigging out in the field in the dark though, a simple uni to uni can get you fishing faster, so its important to know the knot cold.The fast and easy way to tie braid to mono is with a micro swivel. Check out spro power swivels. Size 8 is really small and good to at least 50 lb I think size 10 even smaller and good till 35
This. I've switched to swivels on my streamer rigs, even for trout. Fast, strong, easy, and as an added bonus it keeps your line from getting twisted.The fast and easy way to tie braid to mono is with a micro swivel. Check out spro power swivels. Size 8 is really small and good to at least 50 lb I think size 10 even smaller and good till 35
I agree about the hitch, if it’s not under pressure it’s hard to believe it doesn’t come undone. The only part of that method that took a few tries to get comfortable with, was getting the mono to straighten out after the wrap.saw this - and while it makes sense, it is a scary knot!!!
hard to believe the half hitch at the end doesn't create a bend that weakens the system, but apparently knot 😉
sweet socks and sandals there...def embracing the Florida lifestyle.Our pond really turned on - got 5 ashore and one threw the hook in about 45 minutes. Little gator was watching me and even charged one of the fish
BTW Nice Catch
Gators! No thank you! Do you ever use a ned rig or wacky rig the senko style? I do much better with those set ups than texas rigOur pond really turned on - got 5 ashore and one threw the hook in about 45 minutes. Little gator was watching me and even charged one of the fish
