tinfoil is the same concept except its basically free
What's the rating on the two bags?
give it a try tonight, out in the yard.
More dicking around with gear setup. The never ending battle.
Doubled up on the clamps for the harness. Because better safe than sorry. Setup is dumb light as it is so no biggie.
It's the new Specialized Burra Harness. It's basically a lighter, simpler version of the BarYak/Revelate setup.What harness is that? Did you change to this from the Revelate harness?
Setup looks very neat!
It was -25 degrees during the 60k Fat Pursuit this weekend. At that point white gas is all that will burn but I'm not investing and testing a new setup this close to the race. The MSR shield has a floor as well so hopefully it will work. I've gotten stories from both sides.
Sweet. Cool to hear that you are now using a lighter, and hopefully better harness.It's the new Specialized Burra Harness. It's basically a lighter, simpler version of the BarYak/Revelate setup.
Wood be cool if you could zip all the bags together to make a bivy.Is there a tent in this set-up somewhere?
There's a Bivy in there. It's all rolled together so all I need to do is unpack it, roll it on the ground, and crawl in. 2 minutes.Is there a tent in this set-up somewhere?
