Starting my ride this morning, in the dark, the sky was not as clear as the last few mornings but I could still see the stars through the thin clouds. It was a bit humid for a late September morning and warmer than the past few and the dew was promising to be thick. As dawn approached, the sky turned a dull pink that ever so gradually became deeper and deeper to the point that the woods I was passing seemed to be on fire. As sunrise came closer the pink turned to a dull orange and the sky took on a painted look with some ling, strung out clouds on the horizon. I hit a field with a full eastern view about a min before the sun peeked over the horizon. It wasn't the most spectacular sky I have seen this week but I have seen it nonetheless and I, we are seeing them for you.
I hope in your mind's eye that you are seeing the sun rising as I just explained and even though the night you may be seeing has lasted longer than you would like, your dawn will come gradual.
Starting my ride this morning, in the dark, the sky was not as clear as the last few mornings but I could still see the stars through the thin clouds. It was a bit humid for a late September morning and warmer than the past few and the dew was promising to be thick. As dawn approached, the sky turned a dull pink that ever so gradually became deeper and deeper to the point that the woods I was passing seemed to be on fire. As sunrise came closer the pink turned to a dull orange and the sky took on a painted look with some long, strung out clouds on the horizon. I hit a field with a full eastern view about a min before the sun peeked over the horizon. It wasn't the most spectacular sky I have seen this week but I have seen it nonetheless and I, we are seeing them for you.
