when maurice makes comments like this and i feel like i should get back on a tricycle. and stay there. boo-hoo for me.
RV, no lock out anywhere. Most parks in NJ don't warrant this for me.
You should look at how "smart fork" fads come and go. Fox stopped making Terralogic I believe because people prefer an actual lock out or nothing. Other companies had followed the same path before. Interesting.
Fox Triad I believe. Or Float. It's the same thing just a special name for the '06 Specialized. I believe they went with a different shock after that but I'm not sure.
that was my guess - the RP3
Not sure what you guys mean that it compares to an RP3.
Ah. I think triad=flaot, but had a different name for the DumpTrucker. But wtf do I know? I just learned how to use the lock-out 2 days ago.
gotcha, my bad use of terminology.RP3 doesn't have lockout: propedal light, propedal heavy, propedal off I think.
The bottom line floar only has a rebound adjustment, that would be the Float R. I dont know if they make just a float
They do make a FLOAT or used to. That is what I have on my Kokopelli. It doesn't have a lock out, but I don't miss it. I always try to keep it around 180-190. Pretty solid shock, never serviced it and still going strong. It outlasted the frame !
uh, never.I actually do not, I probably should. I used to and it never really lost any pressure between so I left it as it was. But I may have just set it low at one point and never bothered with it.
Good question about servicing. When was the last time you had it serviced?
