Juggernaut
Master of the Metaphor
Was there this afternoon.  It’s a hoot!
			Did you ride the biggest berm of all time??Was there this afternoon. It’s a hoot!
I most certainly did. If that thing curved anymore it’d be a circle! 😍Did you ride the biggest berm of all time??
I am pretty proud of what we have done here thus far. We are not even close to done, but once the word gets out, this place will be a madhouse.
We are working really hard to keep it high and dry. That said, please offer some respect after a heavy rain and give it a fair chance to dry.
There is one kinda sketchy spot but I think with more use it’ll work out fine.
Mud hole?? I just need a few dry days to firm that up. There was no culvert there and we basically created a Dam. On Wed we threw in a culvert and now the whole hillside drains nicely.There is one kinda sketchy spot but I think with more use it’ll work out fine.
Actually, the only mud hole on the new work is by the excavator where the treads tore it up. 😉. The sketchy spot is towards the end of the run, there’s a left hand berm leading to a transition rise which immediately precedes a right handed berm. None of this by itself is problematic. The issue (imo) is that exiting the first berm there is a water egress cut on the outside (right side) of the turn which is fine, you need to go left anyway to setup for the right hander … but there is a tree near the (left) inside that at speed may be a bit much for the novice riders that will be flocking here. Selfishly, with a little more room (and practice ) I MIGHT be able to use the riser to gap to the top of the second berm. Words I NEVER thought I’d say. 😊Mud hole?? I just need a few dry days to firm that up. There was no culvert there and we basically created a Dam. On Wed we threw in a culvert and now the whole hillside drains nicely.
Lets get you out there and we can fix it!!Actually, the only mud hole on the new work is by the excavator where the treads tore it up. 😉. The sketchy spot is towards the end of the run, there’s a left hand berm leading to a transition rise which immediately precedes a right handed berm. None of this by itself is problematic. The issue (imo) is that exiting the first berm there is a water egress cut on the outside (right side) of the turn which is fine, you need to go left anyway to setup for the right hander … but there is a tree near the (left) inside that at speed may be a bit much for the novice riders that will be flocking here. Selfishly, with a little more room (and practice ) I MIGHT be able to use the riser to gap to the top of the second berm. Words I NEVER thought I’d say. 😊
Just rode it, looking good!!!We made it to the top of the new trail today. This last bit of work was nearest to the basketball Ct and the only spot holding water.
Pulled the machine out for some service.
Very glad to finish this section.
#franksFlow is what I’d call this segment.
View attachment 264369View attachment 264370View attachment 264371View attachment 264372
I bet it was soft. I won't be back there for the next ten days so chime in if it needs attention.. @Kirt is sure to go back after this rain tonight to see how it drains.Just rode it, looking good!!!
That will get redone shortly. Ignore the devastation I left behind.. I was melting ...It wasn't bad, the softest part was where you crawled the machine in/out a long the fence line.
Fixed it todayIt wasn't bad, the softest part was where you crawled the machine in/out a long the fence line.
How are you linking the new outside left trail? I had a loop which included the two flow trails and also the outside right, which I've been calling the Longest Mile. With the new trail, I'm just hitting the Longest Mile backwards around to the new trailDry and loose today midday (but tstorms are a-coming). Upper perimeter trail flow work is new since my last ride here and it's very nice! Trail section around the defunct basketball courts could use a haircut soon. Finally figured out how to link everything together nicely and do laps of Stop Sign and Shed. Both seem rockier/looser than i remember. Got sketchy at speed in a couple places. Have some ideas to fix a couple spots but don't want to nit-pick. Keep up the good work!
I come from Ballfields/Black, do the Cromwell perimeter counter clockwise (start rider's right from Black and loop all the way around). The first time i hit Stop Sign i come from "Hump Trail Access". Then when i climb back up for laps, i follow the red lines and you can get to either DH trail at the fork. On my last climb up, i do the full rider's left perimeter trail to get up above Hump Trail Access and take that back down and hit one of the DH trails back to Black.How are you linking the new outside left trail? I had a loop which included the two flow trails and also the outside right, which I've been calling the Longest Mile. With the new trail, I'm just hitting the Longest Mile backwards around to the new trail
