qclabrat
I'm surprised I didn't see one in your handsome garageTwo post with stands
Drive on with rolling lifts, center pans for storage.
Single post storage lifts
My brain hurts
My brain hurts
My daughter's car is now total loss.
I guess I'm going car shopping
Definitely sadNot sure to like or sad?
Is that the car you just put on new tires?Definitely sad
Nope. That was my son's car.Is that the car you just put on new tires?
Impressive.Had a little the other and finally got to finish this project.
Dug out my harbor freight trans jack that I used for the mustang.... This was super help in getting things lined up
Got it close then lowered the car down on it
Bolting it in was pretty easy outside of the control arms... They needed some pry bar work for get lined up
Got out my spray gun and my surface shield and gave everything a proper hosing down... Maybe it this one won't rust as bad
View attachment 259896View attachment 259897View attachment 259898
My god does it drive soooo much nicer
Only issue is that the tc/abs lights are still on.... I didn't swap the sensors that were on the sub frame I got from the junkyard... Figure I'll drive it for a bit and see if they shut off
So back in action and it only cost $200, can't complain about that
Impressive.
How are you with steering racks for a 2013 Santa Fe 🤣
Impressive.
Actually, the thing that was really nice about this swap is that I didn't have to remove or replace any lines and all bolts were easy to get too..... I have done steering racks, some are buried and the lines suck to get on/off... Granted without my lift, this would have been a much bigger paini promise, the steering rack is a much smaller job than that.
For my 100k service I bought Anti-Freeze at the dealership. It wasn't expensive and figured it's the easiest way to NOT have an issue. It's so hard now knowing what to properly put in a car now as you can just turn your anti-freeze into a gel by a small contamination of the wrong stuff.And engine coolant... woe be you if you mix the wrong coolant types...
Between my old TDI, the MINI/BMW and "green stuff" for the older cars - and then second bottles with 50:50 mix (distilled water only, of course), the coolant shelf in my garage was looking stupid... Oil was similar, although got better in later years as the VW and MINI both take M1 0-40 Euro formula. Although now I have 5-20 for the minivan.For my 100k service I bought Anti-Freeze at the dealership. It wasn't expensive and figured it's the easiest way to NOT have an issue. It's so hard now knowing what to properly put in a car now as you can just turn your anti-freeze into a gel by a small contamination of the wrong stuff.
I did the same with the trans fluid as it was reasonably priced.
Seems common among Porsche aficionados, the biggest issue with it would be the solid deck doesn't allow you access to the bottom of the car which in my opinion is the precise reason why you would want a lift...the older version appears to give you a little more access but I'd rather have two separate scissors/platforms, one on each side of the car, for maximum access. @UtahJoe what model is yours? I will have to get back to my Eclipse at some point...I'd love one of these but not sure how I'd get this off a rented pick up truck. Anyone have done this before?https://www.facebook.com/share/1FztmNHC9Y/
Rent a fork lift from Home Depot. Now figure out how to get the fork lift home.I'd love one of these but not sure how I'd get this off a rented pick up truck. Anyone have done this before?https://www.facebook.com/share/1FztmNHC9Y/
