Camp Cromwell property
This trail and the Stop trail will be 1-way soon. I have the signs I just need to put them up.
If you read this, please stop climbing both of those trails.
Thanks!
I previously used it as a climbing trail to get to the stop trail… no more! Very impressed with the changes.
And done.
Rode today and ran into @Kirt while on the way in. New section of Stop Sign by the main building is awesome and Shed is like night and day from a month ago. With a little rain the trails will be incredible. Been able to get about 8 miles from the ball fields.
There's a dead ash tree by the bb court gate.
Where is the Shed trail? Is it at the top of the gravel trail?
no, when entering the properly and making a left onto gravel trail and climbing up from there, the gravel trail splits part of the way up...if you take the right split the entry to the shed trail literally has a shed right next to it...if you take the left split, it'll be your first right turn, which takes you thru the grassy knoll to the shed entry
i suck as an artist but follow either red line (post split) and the red box is the shed
EDIT: @Norm looks like shed trail needs naming in TF
Thanks, I usually just ride the cromwell loop counter-clock wise, will check this out!
make sure to also check out stop sign trail, 2nd right on either gravel fork and the entry has a, you guessed it, stop sign (named correctly in TF)
these 2 trails have had the most work and it shows (in a good way)
depending when you ride happy to meet up and give a tour
So 1 of the efforts we'll be working on next is making a trail to get you to Shed without taking the gravel trail. In general we want to keep the bikers off gravel long-term. So we have something in mind to help this.
yeah, there is a mostly non-gravel way to get to shed (and stop) but in terms of explaining and drawing gravel is easiest/most direct haha (like i need to tell you!)
