1speed
Sweet build. A dropper would complete that bike.
@JDurk - I'm a registered NeverDropper ...what's the gear ratio?
@NJsinglespeedtrek - right now, it's a 34:19, but since it's a Melvin tensioner, I can run anything within 20 teeth of chain wrap. and that covers pretty much every gear I'd ever use. That metric is typically applied to differences in front chain rings (for so-called "Dinglespeeds") but the same principle can be used to figure out how many cogs you can use without resetting the tensioner - basically, I can go between a 16t and a 22t without having to reset tension. And that's wider than the range I'd ever use with a 34t ring (I'm pretty much staying between an 18 and a 21 these days.)
