but functionally what’s the difference? Are there pros/cons to one or the other?
Awesome. Thank you!!The extended is for 5+ inch tires. I have the standard and run 26x4.8 Minions. It isn't supported according to Manitou, but I've had no issues.
Also, do it.
I bought my wife a Mastodon Comp last year (MY2019) and noticed something in the travel change docs. All MY2019 and newer (STD & EXT) use the same stanchion length; 367mm. See page 9 at the link below. In my case there was a White Dot on the IVA cap meaning in was at least MY19. So if buying new you should be able to get any Mastodon Pro or Comp / any length and change it to what works for you. In her case I bought the 120 Pro STD and we are using Minions 4.8 F/R. Like @JimN said above the STD will work but I noticed at full travel the aftermarket fender bottomed out on the crown which cause a small tire rub noise. I have a Pro 120 EXT on the same frame (20" rather than her 16") and like the geo at that length so... I used Manitou spacers and brought hers to the 20mm higher EXT length.
Great forks! I prefer Manitou and have been using them since the mid 2000's and have Mattocs on several bikes. Very easy to service with the toolkit.
Thank you!! based on the UPC and Mfg # for the one at Universal Cycles, its the Pro 100 STD version.. I was looking for the Comp, but that seems to be out of stock everywhere so I went with the Pro. I don't think I'll have any regrets going with the better version.They are hard to come by but here are a few potential options. The photos are the newer decals and being we're at MY21 they should be the longer stanchions but you may still have to confirm.
Worldwide has the Comp/STD
Universal Cycles![]()
Manitou Mastodon Comp Suspension Fork - 26", 120 mm, 15 x 150 mm, 51 mm Offset, Matte Black, Standard
Shop & Learn About The Manitou Mastodon Comp Suspension Fork In The Suspension Fork Collection - Features & Specs: Axle to Crown Length: 511, Brake Type: Post Mount 180 MPN: 191-35528-A102 UPC: 847863026439, Color: Matte Black - The Mastodon is a true all mountain fatbike fork with stiff 34mm...www.worldwidecyclery.com
(COMP 120 STD)https://www.universalcycles.com/shopping/product_details.php?id=104327
(Pro 100 (no EXT/STD listed so newer?)) https://www.universalcycles.com/shopping/product_details.php?id=103494
I *may* have gotten the last of the 100mm Pro STD from them but this place has it as well:OMfG - they all are sold out already!!!
i'll just get a new bike and sacrifice something to the fire god.
I *may* have gotten the last of the 100mm Pro STD, but I did find another 120mm Comp STD if you're open to that:
https://takeahikeshop.com/products/manitou-mastodon-comp-standard-fatbike-fork-new-2020-model
In case you do get weak, I just updated the links.. they have the 100 Pro Std too. Glad to spend your money for ya!glad you got hooked up, and got this thread back..
I'll probably wait until the middle of summer when the northern hemisphere isn't thinking about fat bikes!
Thanks for the link.
Doesn't mean i won't become weak later tonight 😉
@Patrick, the 100 Pro is back in stock. You an make it 120 if you prefer..
Manitou Mastodon Pro Standard Gen2 FatBike Fork
Manitou Mastodon Pro Standard Gen2 FatBike Fork :: From $689.00 :: Manitou 26/27.5 Inch Fat Bike Forkswww.universalcycles.com
This fork is so good. I think I'm gonna pick another one up before next winter. Snowshoe groomed single track is taking its toll on my shoulders.
