Like was mentioned in another thread, that depends on tire size and sidewall stiffness. I'm 190 and have 20-22 psi in 2.2 conti trail king and 2.4 conti x-king on my "CR and anything to north" bike. Btw I always use BC / Protection versions of conti tires.curious what folks are running on their tubeless set ups
I find 15-20 is too low as I'm feeling the rim at times
weighing in at 155 if it matters and mostly at CR
Sorry if I am hijacking this thread but is there are huge difference in regards to PSI from tubes to tubeless if everything else equal?
I remember Jdog saying you should feel the tire bottom out and feel the rim when going through rock gardens. I've found the best tire performance when my psi is set up this way. It takes some trial and error but when you get it right you know it.
Tire pressures will vary from tire to tire and it depends upon the weight of the rider as to what your psi should be. I can get away with 17-18psi on my Ignitors up front and 18-19 psi with the same tire in the rear. Also I'm 145lbs.
