very cool. the rest of the week looks super below freezing, i assume this is good
sweet! wood skate on
never owned skates :cry:
Do you have a hose connection inside (no freeze) to resurface the ice with water? That think would be so flat and clean after a few coats of fresh water and these low temps...
Excellent!! You should have it dialed in over this period of super cold weather.
Meh. So I went home today to go put some more water in and some water just have froze between the spigot outside and the value inside the house so no water is flowing.
I am out of the house now, but my hope is that I can get some water to flow out of the spigot on the other side of the house, otherwise I may need to run a hose out a window from the washing machine hookup.
I am bummed bc I really wanted to get more water on it tonight to increase the ice thickness with the super cold tomorrow.
propane torch Brad, about 5 minutes or less and it will be flowing. If you don't have one go buy one they are cheap. i should say heat it up from the outside and not near a solder joint, this is if your spigot is through concrete of course and not vinyl...
