@pooriggy and some of the crew walking the Ditch Witch up trail. Easy to get up with a bike - not so much with a skinny and top heavy machine.
Pic of the yesterday's work area before the TM started. Iggy said the ground water was coming out an making a total mess of the trail (blue line). So much so a new trail was being formed to the left (red line). Bit of a bummer the roots had to be cut out for the drainage work but this section of trail was the definition of blown out (width wise). With the amount of traffic and weather this trail gets I'm sure there will be some added tech soon enough.
While Iggy and the rest of the crew were dealing with the drainage issues below, Knobby and I went up a bit to dial in some of the work from the previous week.
@knobbyhead massaged a turn (green line) that seemed like it was pushing riders out to a drain we built last week. A cut root and added rock and dirt give it a natural looking bank and should help direct riders. We also cut out a water drain (blue line) that was full of rock and roots. Those rocks and the good material were used to build back a corner of the side of the trail that was washed away from water draining in from a rogue short cut trail near by.
Another view looking down of the area. Blue line is the projected water flow. Red is where we built out about 2ft. The green lines are the climbing line with a steeping stone and a little skip option going downhill. Between them is the same rollable root drop.
Funny comment from a runner while I was working - he said something along the lines that we were taming a fun section for when he mtn bikes. He kept running but wanted to tell them that we didn't remove any rocks and last week I actually added some tooth set stone to help dilute water before it builds up power. Plus - how did he not see a potential root skip to hip landing?? It's nothing big but should be fun
Mid TM view of the rocks we piled to build up the eroded area. That was the first round. More were added to bring it out even more. Should provide some chunk once the material settles and fills in the cracks.
