iman29
I did this same repair last summer but I had to swap the whole valve because the stupid handle screw was welded on with rust.Well my shower mixing valve started leaking through the stem. Luckily not into the wall.
Just a drop every now-and-then. Later it started leaking at the showerhead. Drips.
Then it became a constant stream running down the wall. I should have fixed it when it was a drip.
(see hard water stain)
Anywho, i was smart enough to install a valve with service stops, just in case i needed to replace the shower valve body.
I go to close the stops today, and the hot will not shut down, and it started leaking at the stem for the stop into the wall....
Great! Well it is a Kohler, installed in 1998 - I gave them a buzz, and they are sending all new parts for free.
Meanwhile, i have the hotwater shut off - but just in case someone wants to shower,
I created a temporary solution out of the greek yogurt container...lucky i finished that up yesterday!
View attachment 120292View attachment 120293
I didn’t need the yogurt cup tho but I did have to shut off water at the main because the valve stops were also not functioning properly.
