Not sure how correct this is, white industries has the micro spline freehub shortly after xtr was realesed. Industry nine has it too.
White Industries has a 12-spline body that just happens to fit the micro-spline cassettes. Looks like a way to dodge the licensing fees.Not sure how correct this is, white industries has the micro spline freehub shortly after xtr was realesed. Industry nine has it too.
I saw that wolf tooth is making 12 speed compatible chainrings that fit xt 8000 cranks.https://www.wolftoothcomponents.com/collections/shimano-12spd-hyperglide-compatible-chainringsno need to get new shimano cranks right? just shifters, cassette, derailer, chain and freehub.
i have a feeling im going to end up with a 12 speed setup by end of the summer.
i have the sram DUB bb with a gx crank and rest is xtr, trying to avoid buying new cranks and getting a new bb installed. i doubt wolftooth is going to make a ring for sram cranks for shimanoI saw that wolf tooth is making 12 speed compatible chainrings that fit xt 8000 cranks.https://www.wolftoothcomponents.com/collections/shimano-12spd-hyperglide-compatible-chainrings
There is nothing unique about the chains, so shouldnt make a difference between sram/shimano.i have the sram DUB bb with a gx crank and rest is xtr, trying to avoid buying new cranks and getting a new bb installed. i doubt wolftooth is going to make a ring for sram cranks for shimano
the claim is there is some kind of uniqueness to the new chain that works better for hyperglide. i already have a wolftooth oval on the sram crank just want to run the rest all shimano stuff. i think it should be fine, pics on wolf tooths website do show any gnarly tooth differences so i can see why it wouldnt work unless the 12spd chains are thinnerThere is nothing unique about the chains, so shouldnt make a difference between sram/shimano.
awesome, thanks for that info. according to marketing wank ill need new cranks and bb then. i knew i should have just went with a shimano bb and whatever cranks i wanted when i built this bike but it already had the dub bb pressed in so i ran with that.Who knows if marketing BS. I plan to try the crank.
They are thinner, yes. Ever since above 8spd, they each spd has gotten thinner. But I have run shimano chains on SRAM without issue.
Guess we have to wait for pink bike or Zinn to do a compatibility test.
From Wolftooth:
The new Shimano XTR, XT, and SLX 12spd Hyperglide+ chain works differently than other products on the market so Wolf Tooth engineers developed a completely new tooth profile to provide optimal chain retention and durability when using this new chain technology.
- The new HG+ chain interacts with the chainring much differently than a traditional wide/narrow design. Wolf Tooth engineers spent the time to understand how the system works and design a new tooth profile that is optimized for this system.
- Engineered proprietary tooth profile maintains the quiet and smooth performance of the HG+ drivetrain with legendary Wolf Tooth chain retention.
- Prevents premature ring and chain wear that can come from non-optimized profiles.
So the whole conspricy with the new freehub, microspline, not be open to manufactures is hogwash. Who knows if some manufactures truly aren't getting the license, but DT Swiss, I9, Project 321 and others, all have microspline either available or coming soon.
In any case, I picked up the XT crank and chainring and have 4 rides on it, including some rough DH's. Any concern about the "new chain retention" tech with the chainring teeth is BS. It is just a version of narrowwide. I am running it with an 11spd chain an the only noticeable thing is that it may be a tad noisy with the minimal amount of lateral chain movement.
FYI, the Shimano 12 speed chain is narrower and has specific profile to fit the cassette. It will most likely shift better.
I have been running XTR since April ~ 900 miles on my Ibis Ripmo. I am running RaceFace Next SL cranks with a Raceface Shimano 12sp compatible ring. The tooth profile is not narrowwide it has thick-thin teeth similar to Wolftooth. After dropping the chain a few time which never happened before with a RaceFace normal NW ring, I added a MRP chain guide.
The stuff is amazing.
Right, narrower chain, no problems shifting with 11 speed, which is expected since it is just the front chain ring. I had reported because shaimno was seeling a new / better 12 speed chain wiht dynamic chain engagement and that it wouldnt work with 11 spd.FYI, the Shimano 12 speed chain is narrower and has specific profile to fit the cassette. It will most likely shift better.
What is the chain line with your setup? I'm looking to switch to XT 12 speed sometime in the future, but for me the missing piece of the puzzle is the chain ring as I run a Next R crank with the OneUp Switch setup for super boost. Unfortunately OneUp has not a Shimano 12 speed compatible Switch chainring yet.
Also the new XT components don't seem too readily available just yet through the usual outlets...
As they say your mileage may vary.Right, narrower chain, no problems shifting with 11 speed, which is expected since it is just the front chain ring. I had reported because shaimno was seeling a new / better 12 speed chain wiht dynamic chain engagement and that it wouldnt work with 11 spd.
