@Patrick is that the Weber Performer serial #00001?
You need a rib rack, that will def help to get air flow.
I put a small water pan in the center, then put the baskets in or use the snake method around. I think I normally run 2/3s open on the bottom and 1/2 to 3/4 up top.
Ribs looks real good. I had hopes of smoking something this weekend, but it never happened. I’ve been wanting to spatchcock a chicken to try it out.
i didn't even think to use the rack!
yes - it is ancient! it matches the old avocado refrigerator in the garage!!!! 😀
i didn't want the drippings ending up all over the bottom of the kettle.
wonder if i could get the water pan from the rocky mtn under there with some al foil?
then use a rack, and bend the ribs a bit to drip in the pan?
i had the upper vents cracked enough to see they were open. bottom at about 1/2.
