Installed a much needed new chain
@Santapez hooked me up with some skinny 29er wheels, so i sprung for a second xx1 11sp cog/dome(?)
Set up tubeless after a 5 minute battle! (used the strap method with the valve core removed)
half a twist of the barrel adjuster to quiet the shifting, and centering the brake caliper. Just need to flip the insert on the shock, and i'm
good to go. well, on the tow path anyway. #bumthumb
bike is going to lose about 1lb total. the other wheel is at halter's - that should happen soon.
I had Jay's higher end 27.5 Tallboy for a month, then my 29er. I much prefer the 29 version.
Actually I lied. 27.5+ is the best thing ever. Someone buy my extra 27.5" wheelset that would fit a tallboy, taken off Joy's 5010. 🙂
@fidodie You're going to like it so much better.#29er4life
while i was at it, i fixed that b+ wheel that cause the failure at the sourlands and CR.
Pulled the tube (again), straightened the dent in the rim, and mounted-up the better of the two ignitors - rather than the rocket ron. didn't like the braking of the rr,
but do like the cornering. i'll probably run that up front of the hardtail, in 27.5 version (@jdog suggested, since i'm going with a longer travel fork.)
can't wait for thanksgiving! ugh. towpath century coming.....
@Ryan.P ?
wait, don't you want to run b+ in the winter?
trying to narrow down some fork choices, anyone have a useful comment on using a SID with 120mm travel for a single speed?
was first considering beefier options such at the MRP Loop, but now I'm thinking light might be better.
I run the SID WC on my SS (100mm doe). The 120mm is too flimsy for me. It just flexes way too much. I run the Fox 34 120 on the FS. You're a whole person thinner than me so maybe it'll be ok for you.
was looking for more bike storage ideas and came across this one (couldn't find @hotsauce 's thread to add to tho)
But seems easy enough to DIY, thinking just a 2x3 for the wheels and a cord fixed to the wall to provide the right angle to over lap bikes by hooking on to the top tube
anyone tried make something like this?
Interesting. I didn't realize from the thumbnail that it was the Pedal spindle that's securing the bike to the wall.
You could do the same thing with an eyebolt in the wall and a length of rope with a hook on the end; just put the hook through the pedal body. A sliding tension knot (like you use on tent fly's) could be used to change the length for different bikes.
I think I was just posting in the DIY thread.
I looked at these a little but basically it's no different than something designed to hold the bike up horizontally by the top-tube, just using a different mounting location. Although if you don't have a flat top-tube or have other stuff in the way, the only option may be the pedal spindle.
I ended up passing on these simply because I don't have any wall space that's not a door/closet or in an area where a bike wouldn't make sense (i.e. over the bed). My end game is blowing a hole in a wall to take advantage of dead space under a U-shaped staircase. Hopefully it's sorted out by year end!
that's the part I don't buy into. Easy to DIY, but leaves very little customizing on the angles and spacing
what about using a 6' long shelf standard with different length shelf brackets - a little bit of modification to hook the pedal. Standards give height flexibility and the brackets come in different lengths.
Played around with volume spacers for the first time today in both my fork and shock. It was surprisingly easy to do. I'll see how things have changed this weekend... If I guessed right I'll get away with slightly less pressure making things a bit more plush but not bottom out too easily.
Which fork and shock?
I'm not skinny, just small boned
that's why I've broken myself so easy....
think I'll regret getting anything with a 32 for 120mm or greater
more money to spend 😳
