Can't believe she's driving already! Convertible? When I turned 17, my dad gave me a '66 Mercury Monterey that he got for free from some guy at work...I've been pulling the power steering pump on my daughter's 2015 SLK250 for about 10 days now. 🙂 I stare at it, curse a little, stare at it some more. The engine bay can hold a 5.5L V8 but somehow a 1.8L 4 fills the entire space. My hand is all cut up from loosening the air pipe to the turbocharger. I've probably done about 30 minutes of actual work
I was happy to find a bootleg manual on Etsy that was obviously meant to be navigated with software. It's over 11,000 pages long and takes a lot of searching but it's still very nice to have. I can only see 1 of the 3 bolts that hold the pump. Sigh... Despite the length, surprisingly annoying tasks like removing the intake pipe are just "disconnect air pipe from turbocharger".
That reminds me that I need to order 1/4" ratchet extensions in 30 different lengths.
I'd think that car would expedite her willingness to get said permit...Not quite yet! She doesn't even have a permit even though she's old enough. Kids...
It's a '15 that we picked up from my dad in FL late last summer and road tripped home.
My parents gave me a 1984 Chevy Celebrity when I graduated college.
Right? She was very excited when we got it.I'd think that car would expedite her willingness to get said permit...
So.... Today I spent some time cleaning the hell out of everything, put some parts back on, then I started up the car and moved the steering wheel back and forth. To my great embarassement, it looks like a $5 o-ring responsible for the leak. Dumbass. I had convinced myself that it was OK.I've been pulling the power steering pump on my daughter's 2015 SLK250 for about 10 days now. 🙂 I stare at it, curse a little, stare at it some more. The engine bay can hold a 5.5L V8 but somehow a 1.8L 4 fills the entire space. My hand is all cut up from loosening the air pipe to the turbocharger. I've probably done about 30 minutes of actual work
Well, this thing continues to piss me off on my daughter's SLK250. I replaced the o-ring and it still leaks. As soon as I start the car, it starts seeping. The manual helpfully suggests "replace o-ring" whenever you pull the line. I'm beginning to wonder if there's another o-ring that gets inserted into the pump first. The manual and all the various diagrams on parts resellers are not clear.
I don't see anything wrong with the fitting or the bore where it fits. I do have a new pump but I'm having a hard time seeing what would be different. Maybe I'll order the hose as a hail mary.
I have no idea. Are you thinking that maybe something failed?Is there a high pressure bypass ?
Just guessing...
I found someone on zuckerbook with the exact problem last spring but no follow-up and I have to be approved to post to the group, which is a 50/50 proposition in my experience. Fingers crossed.
RIP Car Forums.I have no idea. Are you thinking that maybe something failed?
Seems strange to just blow by the rings, unless your idea of one more way up front missing?
Poking at ideas here.
this is what I ended up going with after some internetting@UtahJoe Et al. what replacement bearing did you go with? Is it worth going with a Timken or Moog, or did you just go cheapest? Rock Auto?
Thanks! Watching the video looks like a simple job. 😛
This, OEM is a consideration for these kinds of jobs...i always buy a brand name when i do wheel bearings (or anything else critical and potentially challenging to change) buy one with a good quality or end up doing the job twice in short order, i figure my time is worth way more than the price difference.
in this case moog or timken would be appropriate, i put SKF bearings on my truck last fall.
