E-bikes are a thing
Ebikes??
  • I have never ridden one
    Votes: 100 39.2%
    Votes: 11 4.3%
    Votes: 20 7.8%
    Votes: 38 14.9%
    Votes: 39 15.3%
    Votes: 18 7.1%
    Votes: 21 8.2%
    Votes: 25 9.8%
    Votes: 10 3.9%
    Votes: 68 26.7%
  • I hate anyone on an ebike
    Votes: 7 2.7%
    Votes: 98 38.4%
    Votes: 59 23.1%
    Votes: 15 5.9%
    Votes: 16 6.3%
    Votes: 68 26.7%
    Votes: 42 16.5%
    Votes: 14 5.5%
    Votes: 18 7.1%
    Votes: 25 9.8%
  • Total voters
    255
I called it. This is now the winter shoes thread.
@Norm, it's time to ban @Jeremy. :banana:
Wait. Before you ban me, here’s my white MTB shoes!
one more factor, if the battery starts at 100% and depletes to 0 in 38 miles using the 28 tooth sprocket,
will it also deplete in 38 miles with the 38 tooth sprocket, if your cadence is the same you'll just get there faster?
That probably depends on the assistance level more than anything else. You’ll more than likely need to run more assist to spin the bigger gear.
I'm thinking the distance will suffer the faster you go, nothing is free, watts get eaten up, speed will increase, distance will suffer.
Not sure if your bike has an App but in the Specialized App you can tell it to max out the wattage for a distance and it’ll run at whatever that is. I used to set my Vado at 15miles with 50% battery so it could make my commute both ways.
Your battery supplies energy.
Energy is depleted as a.squate of the velocity.
You boost your input based on settings.
You got the cadence q right.
Given the same cadence, without assistance, you'd be supplying more watts. So if energy assistance was the same you'd go farther.
But real world, input+boost, probably isn't going to change much given the cut out speed.
Looking at the edge, if we could pedal 20mph, the battery would never engage and last forever
Or just ride downhill and walk all the climbs. 😁
