Bikeworks
Ok, so I'm at a loss. I'm in the process of converting my flat bar hybrid/gravel bike to a drop bar. Previously it was a mash up of 11s/12s MTB components. I now have all 12s GRX stuff, save for an XT cassette out back (10-51), and a GRX compatible WT chain ring (42t), and that gearing is supposedly okay from what I've read.
Issue I'm having is I can't make use of all 12s. I can get all but the lowest gear, albeit with a bit of slop. Not too concerned about the slop (yet) as I can't use the whole cassette. That said, I have tried to re-index a few times. The limit screws are good, as is the B-screw. I though maybe it was a bad hanger, so I adjusted it. Then I tried a new one. Both the hangers were fine. Cables and housing are all new, too. Took the cassette off, looks to be ok. Shifter goes up and down through all clicks with the wheel off, so that seems okay as well. I'm going to try routing a new cable and see if that does the trick, but not until day after next most likely. Probably will experiment with a double quick link (in the stand) on the chance that I cut it too short.
I'm pretty confident in doing my own work, but I feel I am missing something silly.
