what happens when you take those screws out?
someone might be able to 3d print the plastic part......out of something that can stand a bit more heat.
Yea this. Find someone who can print nylon or pc
That’s been on my to-do list since it broke 4 months ago lolwhat happens when you take those screws out?
Ordered new quill and pulley bearings for the drill press I bought. While that was going on, I cleaned all the business parts, and made a proper set of depth-stop nuts, since the orginals were long [presumably] lost. The press was obviously repainted--well, surprisingly--at some point, since it's 1) the wrong color, and 2) the ultrasonic cleaner literally flaked the paint off the return spring cover/depth stop holder. They got a coat of acid-etch and black enamel. Later on, the whole press might get re-done, but I don't really feel like hanging a 50 pound casting to spray paint it.
I also filled in the newbie marks on the work table, just to get the surface flat(ish) again.
Pictures of the drill press? Anything interesting? I went through similar with an Atlas press that I picked up a few years ago.
It's a Walker-Turner 900 15". The belt cover and original motor are gone, but it has the original JT33 spindle with the removal nut on it.
I found out afterwards that the bearings by SKF were strange metric/imperial hybrids, so there really aren't readily available replacements.
Pictures will follow later when it's reassembled.
Yeah, he's who I got the bearings from. I'm a little irked that a place that (ostensibly) sells parts for precision machines doesn't tell you who supplies their bearings, but I don't have a whole hell of a lot of choice. If they're unsatisfactory, I can always shim/sleeve...Oh yeah, definitely familiar with WT weird bearing sizes. I have one of their bandsaws and same deal.
If you haven't already checked it out, owwm.org is a old resource. There's also a Walker Turner place in CT that's supposed to have parts but I've never contacted them: WTSERVICE@walkerturnerllc.com
How do you legally dispose of fluorescent tubes (neon) in NJ? And I mean legally…
Home Depot will take them.How do you legally dispose of fluorescent tubes (neon) in NJ? And I mean legally…
I was reading about HD taking fluorescent light bulbs, I'll give it a try.
Thanks to all.
+- 6 feet@rlb how far is this off the ground?
careful, -6 is where they tend to keep the bodies man+- 6 feet
Guess I’ll keep it on the plus side, I don’t need any more problems!careful, -6 is where they tend to keep the bodies man
