You mention Timbrens. Did you consider Sumo Springs for load control? I added a set of Sumo S to my '16 Tacoma to tow my teardrop. Tacomas are notorious for squatting with load. Daily driving, didn't know they were there unless I took a speed bump too fast.I'll say because of this I guess. I looks at Timbrens too and this seemed to be the better optio. Since the option of upgrading to a 250 or 350 was not an option 😃View attachment 251099
Basically the same thing as the Timbrens. Went this route based on reviews. So far it actually feels better driving without a load so hopefully it helps with the trailer.You mention Timbrens. Did you consider Sumo Springs load control? I added a set of Sumo S to my '16 Tacoma to tow my teardrop. Tacomas are notorious for squatting with load. Daily driving, didn't know they were there unless I took a speed bump too fast.
I decided to google RAD for pickups and found the web site. But forgot the interwebs is watching so now my FB feed contains this... 🤦♂️Added RAS ( the spring thing) to the truck to help tow the longer heavier RV. Hope it helps, reviews are solid. Only downside is now it has a bit more take than I like. View attachment 251098View attachment 251097
Subarus tend to eat the rears faster than the fronts with the stability control system.
I have to do the rear on my wifes car and im kind of dreading it, especially since she has the electronic parking brake nonsense that i have to deal with, but the parts are here soooo....
Gonna go out on a limb and say yes🤣this applies to most modern cars, especially if the stability control system is activated frequently
Thankfully the Subaru e parking brake is easy to deal with, just need to screw the piston in to compress it.
Already had a high beam out, then a low went out, so I replaced all the bulbs both sides. F you Ford. 13 bolts, two retainer clips, and multiple press in tabs to get the headlight out to replace. Put brand new bulbs in both headlights as I don't want to have to do this again.
Like its a "wearable" part. Why does it need to be so difficult? Could have done the front brakes faster.yea this sucks, but be glad its not a hyundai, i had to pull the fender off my wifes gensis to remove the housings just to change the bulbs.
Life’s too short to burn a PTO day to bust knuckles.unfortunately my wifes car needs to be put into service mode, fortunately my scanner can do that (supposedly). WIll likely take a day off this week to take care of it so will probably report back at that point.
Full on body work....for a headlight bulb!
Well that’s just horrible!Already had a high beam out, then a low went out, so I replaced all the bulbs both sides. F you Ford. 13 bolts, two retainer clips, and multiple press in tabs to get the headlight out to replace. Put brand new bulbs in both headlights as I don't want to have to do this again.
Now we have LED headlights, so a replacement is a trip to the dealer and probably 2k. Hope they last!
