a.s.
Mr. Chainring
Rule #6Not today, Friday night I took on the Mukluk long overdue rollback to 26” fat tires and some cleanup in preparation for GFBD 2023.
Wheels swap, using some ultralight tubes from eBay, worked out great.
Drivetrain adjustment woes, the cassette on the fatback hub that came with my 26” wheels is even further back toward the hub center than on the Hope Fatso…so recycled a Hope spacer and it fit perfectly. No more adjusting the derailleur when swapping wheels.
Left the crusty chain alone, will replace after getting even more crunchiness added during the beach ride. In hind side, very happy I did ( or didn’t do) that.
The doozy…I removed some of the heli tape a hastily installed on the bike when I first built it with less than exciting results. Then I decided to replace the aluminum screws that Salsa used all over the frame and fork and broke one of the ones on the fork. I’m still in shock that I was actually able to drill the broken screw off and remove its remnants without cracking the frame…
Never wrench on your bike the night before a big ride.
Glad it all worked out.
