kjarrett
According to 1Up, the answer is: WD-40 at the pivot points, if anything at all. All I needed to do to get my rack working like new was handled in Step 1. From the 1Up FAQ:Wow, this thread escalated quickly.
What are you all using for lubrication of the pivots, etc.?
Thanks, kj
IF BENT ARMS GET STUCK WHILE OPENING OR CLOSING THE RACK, HOW DO I FIX IT?
Step-By-Step Instruction (Watch our Maintenance Video or follow the steps below.)
The tools required will be a 3/16’’ Allen wrench and two ½’’ wrenches. Proceed through the steps until your bent arms are able to move freely.
Step 1: Adjust the button head shown in figure 1 to the correct tightness. To do so tighten it down fully and then loosen it one half turn. A properly tightened button head should be able to spin with the Allen wrench with some resistance.
Step 2: Adjust the bolt shown in figure 2 at the end of your trays to the correct tightness. To do so tighten the bolt down completely, and back it off one half turn.
Step 3: If a large gouge is present in your Glide Bar, a new Glide Bar will need to be purchased. If these steps do not appear to be your issue, feel free to contact our support team for additional information.
