rick81721
Lothar
it's a metaphor - i could explain it if needed.
Should be good for a laugh - go for it!
I’m debating just getting an edge 130 if the battery life is 12 hours
Thats freakin awesome. and a spudger...... who knew. And the LiPo bag, damn im still finding shit you just taught me, and ive built my own desktops in the past. Well Done.If you've been following the BIYF thread, you'd see that my Elemnt has died on me a couple times.
Bought it new from @FitmanNJ - i think it was a warranty replacement ?? That was a bunch of years back.
Battery wouldn't last an hour in the cold with a full charge - so i fired up the goog and found that wahoo no
longer offered a replacement battery - but they'd give me 20% off a new computer.
Unacceptable.
The goog also found a fellow cyclist that upgraded the battery with a reasonable alternative
$10 on ebay -
3.7V 1800mAh 604050 LiPo Polymer Rechargeable Battery For Camera DVD GPS PAD | eBay
Features: 1> Brand new and high quality 2> It can be recharged repeatedly 3> Built-in protection circuit PCM for prevent over charging or over discharging Specifications: 1> Rated Capacity: 1800mAh 2> Size: 6mm(H) x 40mm(W) x 50mm(L) 3> Operating Voltage: 3.7V 4> Charging voltage limit: 4.20V...www.ebay.com
Here we go - put this, inside there.
TBC
I just use regular cheap clear silicone when making sketchy electronic repairs in gas dispensers , it usually works like a charm . I say cheap so disassembly in the future will be possible without damage.
Thanks to both of you. When it was 11:30pm putting it together I'm pretty sure I thought "Either hot glue, or better yet, bathtub silicone would work great for this" and then proceeded to forget entirely about it.I just use regular cheap clear silicone when making sketchy electronic repairs in gas dispensers , it usually works like a charm . I say cheap so disassembly in the future will be possible without damage.
Need to work up my batteryMan logo!Going to be @Patrick 's new side gig.
thats some crazy shit
This seems to have done the trick, thanks!
Patrick what kinda life are you getting now?total runtime since last charge: 6:45
some with HR monitor ANT+, some w/o
all in sub 30F weather.
extrapolates out to 10 hours or so.
it has also done two firmware upgrades on this charge.
