serviceguy
Mine is self propelled, diagonally maybe?!?!Push mower across, riding mower up/down. I see some of the pros riding side hill and it is scary!
Probably not as steep as yours but my walk behind 4wd works like a charm uphill. My gardener/wife can’t stop thanking me for pushing her into spending the extra money for the self propelled 4wd model.
please say you push mow across the hill, not up-and-down.
https://www.acehardware.com/departm...Vko7ICh2wBgQXEAAYASAAEgJ7IfD_BwE&gclsrc=aw.dsWalk behind 4WD mower? Need more info on this!
could still slip under it - more than likely, the response to falling would not be to let go of the handle.
alternating diagonals would be acceptable - might even look good.
does you British Mower Operator (BMO) wear golf spikes while taking on this task?
i need to get the sweeper attachment that lays the grass in one direction after the deck passes over.
Last fall I found this sitting at the curb around the corner from me while walking the dog with a FREE sign on it.Walk behind 4WD mower? Need more info on this!
Just make one!i need to get the sweeper attachment that lays the grass in one direction after the deck passes over.
The personal pace is the function that adjusts the speed to the person holding the steerer on a Toro lawn mower, it’s not necessarily related to awd, the husquarna awd that you got for free possibly doesn’t have the equivalent of personal pace or maybe it’s broken. It wouldn’t be something too difficult to fix/rig as it is only the throttle reacting to the steerer being pulled or pushed.Last fall I found this sitting at the curb around the corner from me while walking the dog with a FREE sign on it.
Went back with my SUV and snagged it. Cleaned the carb out and changed the air filter and it ran perfect for the rest of the season. Hoping thats the case when I start it up the next week or so too for the first time this season.
I have an old RWD Toro personal pace mower thats getting tired so I found this one at the right time. I have a very flat piece of property but this mower works so much better and the AWD saves some fatigue. The only difference I feel is the speed is not as variable so its kinda more like on/off when you pull the handle to go.
It took some getting used to after using the personal pace thing but I got the hang of it. I don’t think it’s broken I think that’s more just the way it works cause it’s AWD.The personal pace is the function that adjusts the speed to the person holding the steerer on a Toro lawn mower, it’s not necessarily related to awd, the husquarna awd that you got for free possibly doesn’t have the equivalent of personal pace or maybe it’s broken. It wouldn’t be something too difficult to fix/rig as it is only the throttle reacting to the steerer being pulled or pushed.
De- thatching is one of those feel-good home owner practices. You only need to de-thatch if you have more then 3/4" of thatch. De-thatching is right up there with liming your lawn. You don't know the ph, but putting out lime every year feels like you are doing something good.
The pic of lawn above looks thin and sparse. I'd recommend seeding.
Do you feel good now?Post dethatching
There’s always enough to burn if you’re sufficiently motivated.Nah fuck grass I'd set it on fire if there was enough to burn
