When should I drop the audi off for brakes?
QuickJack? How many tons? I'm assuming you would size i for your truck. You really need to write a review, I may have to go with this if I ever manage to free a large enough portion of the garage floor to fit at least one car.
when FedEx shows up 2 days earlier
I have the 5000, and it works pretty well with low carsummm, LMK whenever you get the parts? also bring beer
yup, i got the 7k lb model to support the truck, it JUST clears my wifes car with the smallest lift blocks, not sure it will fit under the challenger, but i can always park that up on some 2x6s to get it under if i need to. Will probably spend a week or two sitting on it this winter since i managed to blow out the front struts
Makes sense. I dont recall if I needed to jack the rear up slightly to clear the small blocks. That car is also lowered a bit more than stock which doesn't help either. It's still a quality piece of equipment and even though i dont use it that often it is a back saverthe 7k is a little over 1/2inch taller than the 5k, which doesnt sound like a lot, but when talking ground clearance, its kinda huge.
No, I just used the ones included. Used them on my Mazda on the weld seam and they have been fine without any real worries.@Danimal did you buy the pinch weld blocks for yours? And if so were they worth it, I can make due without them but think they would make like easier, but $85 for a couple blocks of rubber is kinda steep imo
My package was missing socks.Let me just leave this here 🙃
That made me smile
Bump to Nose bonks make me smile
I still have a threaded 8 ball if you want it.Old school ball shifter.
