Paul H
Fearless OOS Poser
Paul on his rdo tonight...
If they an imaginary bunny hop contest... yep... thats me!
Can you get a Czar under 23? I'd also throw in the Intense Sniper, Scott Spark and Yeti SB100 for consideration
My frame might be real but the rest are still imaginarySuper jelly right now, I wonder where my frame is...Taiwan, Canada, Colorado...or still being made?
are they backed up or just a later release?
No no i really don’t.
Too tight with the plus tire, unless you want carbon rubs on your first rideOk... I was happy!
Look at all that protection
Wooo!!~~~
Look at the stuff it came with. What that screw cap looking thing for?
Borrowed the seatpost from the Crux to put it on the stand.
27.5x2.8 goes in... but only like 2mm of space on each side. Would 2.6 work?
29x2.35 works perfect!
Blur is a newer design. Turner design is old school. Just depends on what geometry you preferWith carbon wheels, czar is 23, Blur is 22. Will run 6K+ tho
I am going out on a limb and say it will be still be under at around 25lbs
Anyone have a scale?
Oh, c'mon! Between your mystery build, @Paul H decision on what 26" rigid fork to install on the RDO and my frame not showing up I' getting palpitations already!
So this is normal and I am supposed to accept it? It looks like f'ed up paint.That not a painted frame. Not unusual for that carbon finish..... think of it as natural splotches in granite.
Ah.... carbon.... HA!If it’s the silver thing, I think it is a steer tube compression fitting. Carbon steer tubes don’t use the standard star nut insert.
That is the correct answer for your build. You want both, trust me. Gonna be light as shit!I call dibs on Niner RDO stem!
Thinking about the Thompson bar
Write me up!That is the correct answer for your build. You want both, trust me. Gonna be light as shit!
Write me up!
Is there big difference in weight?How you fixed for carbon railed saddles?
