@The Landfill of Slacktown
Help him out here. He is basically local and you should have a few in that junk pile I gave you
Lol, I am size Yeti (31.0) but thanks 😊No but if I looking at your picture correctly I got a set of Burton Wind Boots size 27.0 for sale
Thanks Tim but my shifters are SRAM so no go.For the FD, will XT work? I have a brand new direct mount XT that you can have for free.
Thanks, if it’s 9 speed I could use it!Need a rear derailleur? I just found a brand new x9 in my garage.
I think it is. Will check later.Thanks, if it’s 9 speed I could use it!
I think for Front DR it does not matter. SRAM or Shimano FD is the same pullThanks Tim but my shifters are SRAM so no go.
Thanks but that FD is a different type of mount. That looks like the FD for a Cannondale Trigger or similar. I need the one as in the pic (bolt mounts the derailleur to a block on the seat tube using the slot in upper right of the pic).Is this what you're looking for?
I have a cassette too.
I also have two X7 RDs.
Yes, it did come off a Trigger. Damn, you're good!Thanks but that FD is a different type of mount. That looks like the FD for a Cannondale Trigger or similar. I need the one as in the pic (bolt mounts the derailleur to a block on the seat tube using the slot in upper right of the pic).
I think that’s correct up to a point. My shifters are 2010. Not sure of the age of @GSTim ’s FD and if it’s a recent one whether it has the same pull?I think for Front DR it does not matter. SRAM or Shimano FD is the same pull
You give me too much credit. 😃 I have a Trigger.Yes, it did come off a Trigger. Damn, you're good!
