I'm pretty sure the saddle is toast, but it is not old and I like it. Somehow the saddle rails got bent :hmmm: and the seat is cocked to one side. Has anyone had any luck straighteneing a bent seat rail, and if so how did you do it??
Thanks
Once bent, done.....
You could bend it back, but its going to bend again.
Especially once it's bent by a Wookie....the rails will never be the same
I take a guess WTB silverado, and if so send to WTB and they will replace once. It will bend again unless you can get hold of a p6 syntace seat post. I bent two already problem is I really like this saddle and don't have a p6 yet...
It is not likely that you could bend it back.
FYI to all: When shopping for a seat post, look for one that has a wide clamp to hold the rails. It is much harder to bend the saddle rails when the clamp that holds them is wider (from front to back along the saddle rails).
Look closely at the areas of these posts that clamp to the saddle rails. The first one is tiny and is more likely to result in a bent rail.
http://velonews.competitor.com/2009...e-to-provide-better-vertical-compliance_94326
Wider is better:
http://www.lhthomson.com/elite_features.htm
Makes total sense Ben. The post that held this seat is a USE post that has 2 narrow upper clamps and a narrow U-shaped piece of aluminum. Looks like it will always bend rails....time to get a Thomson post.
this is why I said syntace p6 lower craddle is lager then thomson and is a very good post at that with a price tag at CCR for 35 bucks for AL post IIRC.
