sag for Fox forks
I like the aluminum wrench as it works on two different fork sizes.
For example: https://www.ebay.com/itm/254331176107?hash=item3b3751c4ab:g:9LEAAOSwv0tU55aw
Sounds like you probably want to take out a volume spacer.
Got my tool today.
I might differ you guys and thats fine...for me, I dont usually get to concerned how much of the travel I am using on a trail ride (no jumps or drops) Especially with 170mm like on my 38 or my mezzer. I set mine up to "feel good" and I really dont care where that o-ring ends up. I used the shock wiz for my 38...started at 97 psi...it kept saying lower until I was at around 80psi....but as the bike is running thru all of that stroke...to me it really negatively affects the handling characteristics and makes it hard for the bike to not feel like it has a pogo stick on the front. So I said F this shock wiz, put the fork to 110psi with 2 tokens and it was MUCH better. Rode/raced glen park this past week and the fork finally how I like it. But this is me....the more planted my front wheel feels, the more confident I feel, the faster I go.
Used the new wrench last evening on the Fox 34. Confirmed with some forceful body weight travel onto the fork I was getting about 100mm. Bled the air and removed the top cap. 3 volume spacers were present. Removed 1, reinstalled and aired back up to around 70psi. Did the body weight travel onto the fork again. Measured 120mm of travel. Need to get a real ride now. Did not set sag, will do later.
Here to comment about my observations with the Fox 34 130mm on the '22 Pivot T429 v3 last week at TSE. I'm right around the 180lb mark and was using between 72-77psi. Even slamming into rocks all week, I was only using about 100mm of the travel. Was running the recommended rebound setting from full open for my weight, but actually felt it was a little too fast, so went 1 more click slower.
I plan to try between 68-72psi next or lower, which would run more sag, but wondering if I should just remove some or all of the volume spacers and keep the pressure. If removing volume spacers, I'll need to get a chamferless 26mm socket.
Comments and suggestions please and thanks.
I have be dealing with Abbey bike tools, think you would really like their products. Check them out for the socket.
I've browsed Abbey Tools website in the past. Expensive stuff, but I'm sure quality. I purchased the alum. wrench pictured above in post #42 instead of the socket.
I like the wrench but just make sure the fork crown will not interfear in working with the top fork nut. Yes their stuff isn't cheap and they only have a sale once a year.
