Po123
I just upgraded my ride from 3x8 to 1x10. I put a sram x9 shifter, sram 10 speed cassette, raceface cranks with a narrow wide chain ring, and 10 speed chain. My lbs said I may get away with running the original x5 derailleur that came on the bike, but here's the problem I can adjust it so it works well on the low gears or the high but not both, if I pull out enough cable slack so it will go on the 36 tooth cog it then shifts very slow going down or skips gears going down. I am pulling my hair out trying to figure it out. Looking for ideas or thoughts on how to fix it.....
