Dave02
My brakes were getting very soft (lever goes to handlebar) so I bled the brakes.
With the yellow bleed block in place- the lever was nice and firm after the bleed.
Once the wheel was installed and the worn pads were installed, the lever was very soft- pumping the brakes didn’t help. I know that the brakes are supposed to self-adjust for the worn pads- but this wasn’t happening.
Both pistons extend while pulling the lever but retract the same amount when releasing. I cleaned and lubed the piston seals with mineral oil- the pistons seemed to move easier but otherwise no change. I also tried putting the funnel on the lever and pumping the lever to fill the reservoir to accommodate the worn pads. Didn’t help.
I was finally able to get it working by removing the pads and pumping, but am concerned that next time will still be a problem. Any suggestions, other than fire of course? The brakes are only 14 months old.
Sorry for the long post- I know there are many very skilled mechanics here that have been very helpful in the past- greatly appreciated.
