Kickr, kickr core, neo 2 or flux 2? That is the question.
But you just bought a smart trainer
Also did you rip the cassette off with your SS leg powarzzzz
I'm sure I will get my zwift 3 weeks in again. It's tough zwifting in the winter. I'm not supposed to race but zwifting is really racing as everyone hammers. I do a ton of Z2 and when I zwift I tend to stray off the program.
Hi guys,
I'm looking at the Kickr Core for winter training. Does anyone pair this with a mountain 1x setup, i.e. single 32t chainring and is there enough resistance? Apologies for the ignorance on the technology. I guess I'm thinking the software compensates for any given setup but I suppose this calibration can only go so far.
Hi guys,
No experience putting an SS on a trainer, but it may be difficult to even put the bike on depending on tension method, and you'll have to put your cog and spacers on the Kickr. Just keep that in mind. A wheel on trainer may be better in this situation, but then you also need to consider how your wheels is mounted as a bolt on will likely not work. As for resistance, there is a nice range on it, but I think it really works best with a cassette if you're using it to train on to get that sweet spot.
hey - thanks, I should clarify. my setup is 1x10, not SS. would a 32t ring up front be enough to get the most out of the provided resistance?
I use my 1x mtb bike on the trainer. I have a 2017 KICKR.
The core is a streamlined version of the old KICKR (same as what I have) which is a good thing. I use a few different programs including the wahoo app. They all control the resistance so shifting isn't really necessary most of the time.
You will shift in Zwift but even then, a 1x setup will be fine.... especially on a MTB where you'll have super low gearing.
You're good to go.
You're good to go.
jackpot - thank you!
You're good to go.
It’s perfect for that. I have used my ss, my full sus and my road bike on my Kickr Core with no problems.
hey guys - update. I now have a Kickr Core attached to my 1x10 Scott scale hardtail, and it's all good. Fulgaz integration works great. thanks for all the help pulling the trigger on this one!
