What started in January of 2015 is a wrap.
Now it is onto something new! I've started one of those overblown, flush/detox/fat burning/multi-level-marketing/all-hype systems. It is a 9 day system, which is really 11 days, from Isagenix. Why they call it a 9 day, instead of 11. cause 9 is a single digit, and "look at the results from our 9 day system" - the research is questionable, if not outright laughable. The material is all about convincing you it is working, and getting others involved.
Write How you feel, it says. Even provides a tape measure! Also, a grid to write in numbers, and track progress...i'm not doing that.
Why am i doing it? Why not! Cause I can? How bad can it be? we'll see.
So i measured around my problem area - about belly-button height, around the love handles. Will report loss - so nobody gets nauseous.
I'd imagine going from a regular diet to this, there would be a tremendous amount of weight loss - but i'm coming off the colonoscopy, so i've already got the pipes cleaned. My take is that they have quite a bit of purge in their formula.
Schedule looks like this:
s s c c s s s s c c
s = shake c = cleanse
shake days are couple of pills, a cleanse liquid, two shakes, prescribed snacks, light meal, lots of water
cleanse days are couple of pills, 4 cleanse liquid, prescribed snacks, coffee, lots of water
Apologize ahead of time if i'm grumpy.
Started the year knocking on the door of 200lbs (again) - the time spent in florida got me losing weight - then the food poisoning took the weight down a bit more. I've been a bit more cognizant of what gets eaten, to avoid anymore "distress" - so let's call it 180lbs as of today.
I have no weight loss goal.
is this some sort of ploy to publicly state a goal doesn't exist to make it more likely to achieve it?😵
Or is it some MLM trick to state goal afterwards, and claim that it got blown away? Or is it a reference to something someone else posted?🙄
follow along - i'll also be building up the EVO, which should be fun.
s s c c s s s s c c
