Yep! Did the Mohawk Hudson section from Cohoes to Niskayuna and back. Came across Lock 7 and just happened to get there for what the lock tender said was the last boat of the season. The river had been quiet for weeks until then. The boat operator said they were headed to Puerto Rico. They started from Toledo Ohio 😳might be the Thad-Ko Bridge / Mohawk river. Empire State Trail?
When I worked on the tugs years ago we took a small deck barge with an industrial piece of equipment on it from NYC up to Troy NY above Albany and through the canal all the wsy to Lake Ontario. Draft limitation was 10’. LolYep! Did the Mohawk Hudson section from Cohoes to Niskayuna and back. Came across Lock 7 and just happened to get there for what the lock tender said was the last boat of the season. The river had been quiet for weeks until then. The boat operator said they were headed to Puerto Rico. They started from Toledo Ohio 😳
eriecanaladventures.com
There are also boaters who do "The Great Loop" which could be an interesting adventure although most seem to take over a year to make the trip.
nice! you remembered to line up the front tire
I follow some YouTubers who are slowly doing the Loop. I'm guessing that's what the Ohio folks are doing. A bit late in the season, although I suppose if you don't like heat Fall is probably a good time. They can probably be down to the ICW before they have to worry about freezing. Then spend the Winter in PR before heading up the Mississippi back to Ohio in the Spring. Hopefully they miss hurricane season...I keep threatening - the canal boat is a test run to see if we can last a week!
Happy Birthday Robin!!
Thank you!Happy Birthday Robin!!
Happy Birthday!!!Thank you!
