Hair Face
There's about to be a second one up for $19! 😆
Or...but then you may have to change your username!There's about to be a second one up for $19! 😆
I did use it twice. Does it work? Hard to tell as the chain is covered in wax, but it does look to get in there.Does anyone use a strip chip? Does it actually work?
I’m wondering if the strip chip does a good enough of a job to remove the factory grease so that the wax sticks to the chain as well as it would if you did a thorough degrease of the chain.I did use it twice. Does it work? Hard to tell as the chain is covered in wax, but it does look to get in there.
The factory grease is essentially converted to a wax, so I would think there is little impact to how long the wax lasts.I’m wondering if the strip chip does a good enough of a job to remove the factory grease so that the wax sticks to the chain as well as it would if you did a thorough degrease of the chain.
Is the wax lasting as long as it would had you stripped the chain with a degreaser?
That’s what they say….🙂The factory grease is essentially converted to a wax, so I would think there is little impact to how long the wax lasts.
Chain Waxing System and StripChip FAQ
We answer some of the most common questions with StripChip and the new Chain Waxing System.silca.cc
True. It converts liquid grease to a solid grease similar to wax.nope, you cant convert grease to wax, if you want ill get my chemical engineer wife who specializes in lubricants to write up a detailed explanation.
i could believe it dries out/solidifies the grease, maybe that kills its ability to stick to stuff, not sure would have to remember to ask the wife about that. Converting it should require a chemical reaction which seems unlikely to be something that lawyers would let you sell to the general public.
What are you using to degrease? If not using the Strip Chip, are you using the Silca Chain Stripper or the 3 step mineral spirits, citrus degreaser and acetone?Does anyone use a strip chip? Does it actually work?
ThisSilca Chain Stripper
Thanks. After reading the replies from @shrpshtr325 thinking it makes more sense to get the Chain Stipper to use with both new and old chains vs Strip Chip for new chains only. A little skeptical that Strip Chip does the "magic".This
It is a chain i waxed previously. I found the gatorade bottle method to be effective and easiest to dispose of the chemicals.Thanks. After reading the replies from @shrpshtr325 thinking it makes more sense to get the Chain Stipper to use with both new and old chains vs Strip Chip for new chains only. A little skeptical that Strip Chip does the "magic".
@stb222 what did you use for the pictured chain?
