Detroit Michigan actuallyManufactured in India?
Do you have a used car dealer near you? Ask them who they use.We lost a key to our older BMW, the ones with a real key and remote. Lots of locksmiths on FB but most seem like scammers with brand new accounts. Anyone work with a local who can cut and program car keys?
Like this, but you don't need the programed fob to operate the car as we have a valet key as well. I'll see if my mechanic knows someoneso you have a valid key fob and key....
there is probably a vid on how to program the new key/remote -
I found a key cutter in Brooklyn - send a pic, they analyze it and cut the new key.
it was eBay. he isn't on there anymore, but both keys worked flawlessly.
This place seemed pretty popular. https://www.keylessshop.com/fairfieldnjWe lost a key to our older BMW, the ones with a real key and remote. Lots of locksmiths on FB but most seem like scammers with brand new accounts. Anyone work with a local who can cut and program car keys?
$200, have an appointment on MondayThis place seemed pretty popular. https://www.keylessshop.com/fairfieldnj
I'm sure they can give you a cost over the phone based on make/model/year.
xt5, as in a newer caddy suv xt5? like wtf?XT5 went into limp mode on 287 south just before skyline drive.
Was an interesting ride home trying to get out of the way.
it is a heat soak issue with the wiring harness - i'll pull the codes, but I know if I pull the MAF sensor, and whatever other things are in that connector, that it will reset.
Got some work done on the mustang....didnt have much time this weekend, but I got one spring replaced
Thankfully I remembered back in 2020 to coat the front spring bolt with anti seize....back in 2001 I replaced the original springs....these bots were welded into the springs.....Ended up having to sawzall the leaf, then cut thru the end of the spring/bolt.
new one installed....god those U bolts suck....always require being put in the vice first and bent so they will align with the mounting plate
Ya, ill get to the labels...that said...Really hard to paint leaf springs and have them stay nice, they are just naturally rubbing the paint off themselves.this install is NOT @Carson approved, either you didnt clean the stickers off the springs or you REALLY chipped the paint.
Wow, that undercarriage is clean, how many miles have you put in since finishing the restoration?Ya, ill get to the labels...that said...Really hard to paint leaf springs and have them stay nice, they are just naturally rubbing the paint off themselves.
great question...On the first drive after I restored it....the brand new speedometer cable broke about 1 mile into the drive, so the speedo hasnt worked since. But the rear end housing i had powder coated....the car never sees rain or salt, so nothing much to get it dirtyWow, that undercarriage is clean, how many miles have you put in since finishing the restoration?
I'd agree with this response.The answer is as always ..... It depends. Alot of time the plastic ones are just a splash shield they keep water and debris of the belt drive which stops it from making noise and slipping. Although sometimes they do affect airflow and engine cooling(tho not likely on anything most parents would give their kids) The Al or steel ones are more often found as a skid plate type deal where it's actually protecting something more critical.
Short answer is I wouldn't hesitate to drive without one but keep in mind it may cause belt noise or other issues that convince you to replace it and keep an eye on the engine temp for a bit
Does anyone know a trustworthy and reliable mechanic in the morris county parsippany area that won't scam me and won't try to rip me off. It has been pretty rare for me to need one, but my 2017 Ridgeline just threw an AWD error, gonna get the code read at Auto Zone and bring it to someone, but I am very untrusting due to previous experiences.
