JonF
This one resonates with me but its so damn specific, i have to ask where you plucked this gem from?Insufficiently long headtubes for tall riders, coupled with silly-short zero rise stems.
Crowd sourcedThis one resonates with me but its so damn specific, i have to ask where you plucked this gem from?😂
Shimano at least has the 10-45 option available.Can I add in 12 speed wide ratio mtb cassettes? Some of us ride bikes XC where there’s no point in anything over 30 teeth and the only time I would use the 10 tooth is when taking the wheel on/ off.
Give me more gears two teeth apart in the middle of the cluster, not three teeth apart. I have more variety in 10 speed cassettes than the 12 speed I just foolishly bought with my new bike.
Maybe you can find a gravel cassette that works for you? 🙂
Would that work with an eagle derailleur? With a flat top chain?X’plor is a 10-44.
World that work with an eagle derailleur? With a flat top chain?
That was from me. Every XL bike I’ve bought always needs extra spacers, riser/longer stem and riser bars. Every time. Ridiculous. I’m 6’3” so not beyond the norm for a tall person.This one resonates with me but its so damn specific, i have to ask where you plucked this gem from?😂
I went down from a 32 to a 30 tooth because of that reason. I am never in the 10 except if I take my MTB on the road or boardwalk.....Can I add in 12 speed wide ratio mtb cassettes? Some of us ride bikes XC where there’s no point in anything over 30 teeth and the only time I would use the 10 tooth is when taking the wheel on/ off.
Sounds like they dont have any uphill or downhill...what about going downhill?
Dean did this as well with their Ti frames. I called them up on a used frame I picked up and its as you say common to perfect alignment.View attachment 233797Moots basically said that it’s so hard to get the alignment to stay straight during welding that they just gave up and 3d printed one
I don’t love the weld that you see mid-span on the chainstay, but the alignment is unmatched.
SJ basically flat mostly.....what about going downhill?
I was thinking I would try that if I need to.I went down from a 32 to a 30 tooth because of that reason. I am never in the 10 except if I take my MTB on the road or boardwalk.....
It’s basically true. Any uphills or downhills are generally too short to even bother shifting. Great when riding singlespeed.Sounds like they dont have any uphill or downhill...
I have one of these and so far have been pretty happy. It's also crazy light, if that's a thing you care about. Still a wide ratio, though.Ok I peeked down that rabbit hole and decided I didn’t want to go further.
This seems like slightly tighter ratio’d cassette
Because, SS is faster.It’s basically true. Any uphills or downhills are generally too short to even bother shifting. Great when riding singlespeed.
