A few good ones my brother sent me (some NSFW sound bites)
Ya I ordered it with a 5 speed, no touch screen, no electronic climate control.....simple as possible. That said @pooriggy got 300k out of his DCT focusThat's pretty awesome. Not a DCT (powershift?) car, I'm assuming.
Yeah, the price to quality was pretty good. It's crazy what cars cost now.Nothing much I can complain about for an $18,900 car.
This is VERY solid advicethermostat is a possibility but before you go tearing into it.
did you check your coolant level? it almost sounds like the overflow reservoir has been allowed to run out, when the car cools it pulls in an air bubble which then needs to work its way out, and as the coolant heats up it expands, once it pushes the air out the system works as designed.
Thanks for the advice, but what kind of idiot drives around with high temperature readings without checking their coolant level. I just re-filled the radiator and reservoir last week. That's like hitting the trails without checking your tire pressure.
Oh... wait.... I just went out and checked. It IS low. What an IDIOT I am! I just topped off both the radiator and the reservoir with the appropriate mix and will keep checking. Could be a leak (tho I haven't seen any puddles) or could be from changing the upper hose a few months ago and having an air bubble in the system. Thanks for the advice!
In the end we both might have been right. I was low on coolant and the reservoir was dry so that was my bad. I filled it on Wednesday and smooth sailing until this morning, when my temp spiked again. Plenty of fluid in the radiator and re. Time to change the thermostatThanks for the advice, but what kind of idiot drives around with high temperature readings without checking their coolant level. I just re-filled the radiator and reservoir last week. That's like hitting the trails without checking your tire pressure.
Sheesh - pushing $75k before the 4th wheel gets installed...Yeah, the price to quality was pretty good. It's crazy what cars cost now.
How many miles?BMW recommends a brake fluid flush at 30k miles. My neighbor who owns a repair shop said don't bother. What say you?
Well the message has been on since 30k. At about 33. Never sure if it's just BMW looking for a buck. I wish the bikes I sold would flash messages to my customers scaring them into spending more money at the shop.How many miles?
