zmartene
Neat! Time to start lobbying the wife for a bit of those sweet sweet tax refund dollar bills
No more derailleur hanger??
What happens when you hit the derailleur on a rock?
Also, wouldn't the rear triangle need specific clearance to accomodate this specific derailleur? Did SRAM just come up with the bike industry of a BetaMax revamp?!?!Lol:
"Full Mount literally clamps around both sides of the frame itself and eliminates the need for a hanger. This super strong connection eliminates variance and improper adjustment across frame designs. It also eliminates hanger failures and allows the derailleur to rotate backward in case of an impact."
Isn't "failing" the whole point of a hanger? At least a replacement derailleur is only $550 if that rotating backward thing doesn't work when you smash it on a jagged rock.
now it just cracks the frameWhat happens when you hit the derailleur on a rock?
exactly what I was thinking. I thought the entire point of a hanger is to protect the frame in the case of a bad impact...now it just cracks the frame
Ah, so that one can bend too…It's not just connected to the frame on one side, it's connected to the thru axle too.
Ah, Ok, that explains how it would work on both sides of the drop out. Still, making the industry not. Proprietary pushing a proprietary standard? Kind of ‘weird’ approach to it…It replaces the Sram UDH which is an attempt to make the bike industry NOT Propritary. It shifts significantly more positive than current AXS, it's sick.
It's always fun reading comments from people that can't afford AXS talk about AXS. Launch Day is always the best 🤣
Impact on a rock and standing on it can be two different things, I’m sure there was adequate testing before the release.They said there was no bending after standing on it so... Who knows.
Can’t afford and can justify are two different things.It's always fun reading comments from people that can't afford AXS talk about AXS. Launch Day is always the best 🤣
