I like the aluminum wrench as it works on two different fork sizes.Here to comment about my observations with the Fox 34 130mm on the '22 Pivot T429 v3 last week at TSE. I'm right around the 180lb mark and was using between 72-77psi. Even slamming into rocks all week, I was only using about 100mm of the travel. Was running the recommended rebound setting from full open for my weight, but actually felt it was a little too fast, so went 1 more click slower.
I plan to try between 68-72psi next or lower, which would run more sag, but wondering if I should just remove some or all of the volume spacers and keep the pressure. If removing volume spacers, I'll need to get a chamferless 26mm socket.
Comments and suggestions please and thanks.
For example: https://www.ebay.com/itm/254331176107?hash=item3b3751c4ab:g:9LEAAOSwv0tU55aw
Sounds like you probably want to take out a volume spacer.
