rick81721
Lothar
car sales people....
We unfortunately can't do that. It is a doc fee and the doc fee is $499. The state of NJ will not allow us to do that. It is the same price for every customer.
Don't be a sucker - everything is negotiable! 😀
He carries doh. 😂
AAA the car home. And you should be a AAA+ member with the 100 mile tow range free.
I've had good luck with plugs. But also bad luck.Plugs suck. $50 for a patch is getting up there, but if done right it'll last as long as the tire.
No issue, assuming you are talking about the tar strip plugs? They'll just pull it out, ream it out, and throw in a patch-plug from the inside. If they do it right and clean/grind the rubber ridges down on the inside before vulcanizing it in, they'll last the tire. Just never use fix-a-flat or they'll hate you. And most good places will only do a repair in the tread of the tire.I've had good luck with plugs. But also bad luck.
Any issue patching a tire if it's been plugged?
I ask as I wouldn't mind plugging a tire myself as it's easy, but then later on getting a patch.
Pretty much what Magic said. Sometimes you can just patch over the existing plug since it's already filling the channel. If you plug yourself, try and keep track of the object angle so you don't make a new, different hole.I've had good luck with plugs. But also bad luck.
waiting for the shipper to schedule.
how hard is it to find someone to trailer it from lodi to branchburg.
I was pretty good at them when I did that stuff. $50 sounds a bit high, but it does take some time to do right. You're still lifting up the car, removing the wheel and tire, waiting on cement to get tacky before throwing it in, rebalancing it after. It's not a 5 minute thing.
This sounds like some Polish magic. Who vulcanizes?? This isn't Transylvania.
I can be there in an hour with a NOW1FE or AMURICA plate. AMURICA may look suspicious. My rates are very competitive.
