jackx
originally skipped this thread due to repeatedly bad experiences with tubeless
started with Nevegals paired with Blunts, tried about 3-4 times with no luck
ran out of Stans, so gave up the project
moved the Nevegals to Azonic Outlaws, but stayed with tubes
Recently got a pair of 2nd hand Stans Olympics and a set of S-works The Captain
going to give another shot in a week or two, which setup would be the best chances for success?
I'm considering the Stan's setup since I don't have tubes in it at the moment
Have used stans tape, gorilla tape but not the ghetto method
Also tried a compressor to set the beads, another fail
I have set-up S-works The Captain and Raven using gorilla tape ghetto method.
In my experience, using the soapy water on outside of bead is the difference maker for success and failure. I think the soapy water is explained and shown in the NoTubes videos.
http://www.notubes.com/help/index.aspx
Also,once the beads are set and the tire is pressurized, I leave it at about the max pressure listed on the particular tire e.g. 60 psi. I leave it overnight and rotate the tire periodically. I leave it flat on one side for 3-6 hours, then flip to other side for the overnight.
