Paul H
Fearless OOS Poser
why do the job twice?They can install then you can trim down later on, all you need to do is install the housing. You should be able to cut that down and run the remote cable in after.
You guys can drunken brain storm on the Talon internal routingYou need to have us all over for beers and we can have drunken brain storming on we can butcher your new bike
Yes... there is a chance if you buy it first and sell it to me for pennies to a dollarso there is a chance?
Looks like you should be able to route it under the bottom bracket housing, yes?Shiet.... look at that....
Yes sir but It seem like its going to be a bitch to fish it out at the other end.Looks like you should be able to route it under the bottom bracket housing, yes?
The space is pretty tight and I was able to start it going down the seat tube but couldn't do it going up
I saw a video of someone using thread and a vacuum to get a leader through to the hole. He tied the thread to the end of the housing and pushed / pulled it all the way through.Yes sir but It seem like its going to be a bitch to fish it out at the other end.
The hole is smaller at the down tube endWhat is the difference? Pull it through with the what is fished through. ??
Last time I messed up on my defunct Trance, magnet did the trick. But I think this RDO is a lot easier to work with especially with that opening at the bottom.I saw a video of someone using thread and a vacuum to get a leader through to the hole. He tied the thread to the end of the housing and pushed / pulled it all the way through.
You want me to spend $1400 on a fork?
Yes, look how pretty it is!
You beat me to it, and I am on my day off! Yes, that was the routing I meant.
