moray42
Merman
Thanks for the info. So far I hopefully won't need anything other than tires and new chains. Cranks, headset, fork, bars, brakes, etc are all around. Bike was stashed in somewhat rideable condition in an old outdoor playhouse sometime in the 90's. Working on countering the ravages of time right now. Wheels are in the worst condition at the moment. Tires are dry rotted thru. Bearings in cranks and headset still had semi functional grease (i.e. not dry). Seats/seat pans aren't great either, but working with what I have first and seeing where it gets me.What do you think you need? Those old Schwinn-pattern tandems usually used a timing chain on the same side, so, all you would need in terms of "weird" parts are the cranks. You would want one single-speed crank, and one multi-speed (cheap way of doing it). The old cranks used a chainring that had a set of bolt holes for the rear-drive ring to be bolted to. Clever use of spacers will help line up the inner chainrings (which need to be smaller than the driving chainring). Buy the cups and bearings from the same company as the cranks. Wald is a good source (or Tange).
A set of vernier calipers are a good investment for working on older bikes. You don't even really need particularly high-precision ones... The harbor freight digital one is fine.
You can PM me if you need help sourcing stuff; I'm on bed-rest, more or less, for a few weeks (and like old American stuff)
Stripped part of the frame today, and have a bunch of parts bathing in citrus degreaser.
