Dairyman
I am trying to diagnose an issue with my basically new XX1 crankset. It started to creak like crazy from the left side. I swapped the pedals, checked the chain and chainring. I moved on to torque specs and noticed the non drive side nut was loose. I tightened it which in the process made a lot of noise. After taking it for a spin around the block for about 10 min it was creaking and coming loose.
I decided to take the whole crankset apart greased and reassembled it back to recommended torque specs. It came from the shop wtih grease on the nut so i de-greased it and added blue loc tite(torqued to 54nm same as the drive side). Same thing still coming loose. I am looking for any ideas what is causing the nut the to come loose and creak? The non drive side nut says do not remove and the drive side says torque to 54nm. I did remove the do not remove nut since it was already hand tight.
(sorry for any typos grammar mistakes typed this in a rush)
Running on a Pivot LES SS
Sram xx1 eagle 12 spd crankset
kmc 10 spd chain
absolute black chainring
chris king stainless cog
enduro bearings bb92 with a 30mm spindle
the entire setup has less than 300 miles and the new bb bearing are brand new
kmc 10 spd chain
