Smith
I have a BMC SLT01 with internal cable routing. The rear brake in particular has really poor cable routing. The cable is required to navigate a path that leads to quite a bit of cable friction. Not only does this make cable replacement a pain, but it also makes it necessary to increase the spring tension (by quite a bit) on the return spring (on the brake) to get the calipers to snap back open after the brake lever has been released. I have gone through two rear SRAM Force brakes on this bike in ~ 3 years, it seems that the bushings wear out pretty quickly.
So I have three questions:
1) Is this something others with internally routed cables have encountered?
2) Is there a brakeset that would be more durable/better suited for this sort of situation?
3) Has anyone drilled their frame (carbon fiber) to improve cable line, or to run full length housing? (I am obviously hesitant to do this).
Thanks!
Thanks!
