mattsrabbit
Hey folks, gonna put this stuff on Craiglist but figured I'd post here first. I'm in Brooklyn which is a hike for many of you folks, I'm happy to ship at your expense. If any of the prices seem out of line let me know. Also if you want close-up pics of a specific part let me know and let me know what you want to see in the image.
$350 OBO Thule roof rack system with 2 bike racks, crossbars, keys, and Thule tool
Thule ARB47 Aero Blade 47” x2 missing one end cap which can be bought online
460R Rapid Foot pack x4 - I’m unsure what car this will be made for. You may need to purchase a separate foot pack for your specific car/roof/rail system
Thule outride10 x1 Wheel off QR front - Does not come with a through-axle adaptor but one can be bought online
Thule Thu594Xt Sidearm bike rack x1
I will entertain a trade for a similar quality/price 3-bike trunk rack.
$80 Dia Compe BRS 101 Silver Keirin Brake with Left Handed Cane Creek carbon CX style brake lever and brand new cable/housing. Sold as a set with the brake lever.
$40 Pair of NJS Stamped MKS Nuevo pedals with non-NJS cages and leather single straps some damage from pedal-strike to the outside of the right pedal which is cosmetic and will not impact the spindle or pedal performance
$20 Pair of Shimano 600 6207 brake calipers. Complete with pads.
$50 Older Shimano 105 mini-group - front derailer, brake calipers, and indexed downtube 7-speed shifters.
$20 Pair of Tektro R536 dual-pivot brake calipers
$15 Shimano Tiagra FD-4600 10-speed front derailer with built-in chain keeper. Braze-on and unmounted/unused 31.8 clamp
$10 Shimano Tiagra FD-4600 10-speed front derailer Braze-on 31.8 clamp
$20 Pair of MKS-GR9 platform pedals
$20 Pair of Shimano SPD M424 2-bolt Pedals with a rugged platform
$10 Pair of Cane Creek Bar-end levers. No end caps
$10 Shimano XTR FD M953 front 9-speed derailleur. Top-pull, 31.8 clamp on
$30 Well used Phil Square Taper Bottom Bracket. I believe these are serviceable and the sealed cartridge bearings are replaceable. JIS Taper 114mm spindle
$30 Black, High Flange 32 spoke Surly Bolt-on 6-bolt disc hub with Avid BB5R mechanical disc brake caliper (sliver) with used pads
$10 Avid BB5R mechanical disc brake caliper (sliver) with used pads and 20mm IS adaptor
$15 Bontrager Carbon Seatpost with an alloy head. Approx 152mm of total seatpost
$30 Silver Origin8 170mm track cranks with 48t chainring
$35 3T ARX II Pro Stem 100mm 6* angle rise. Great condition, very little wear, no rust on bolts. Logo’s in great condition
$25 Richie Stem, 90mm 6* angle rise rust on bolt faces
$40 Pair of unused, unmounted Hutchinson Black Mamba cyclocross tires. 700x34c, tubeless-ready, dry conditions tread. Great for gravel riding. WIll trade for gently used 700x35 or 36c tubeless gravel tires.
$40 Nitto NJS Stamped Cro-mo track drop bars. Silver, 38cm wide. 25.4 clamp size, 170mm drop, 108mm reach, around 690 grams. Unmounted Condition
$30 Nitto NJS Stamped Cro-mo track drop bars. Silver, 36cm wide. 25.4 clamp size, 170mm drop, 108mm reach, around 690 grams. Superficial scratches on both sides behind the drop
$20 Shimano XT front hub. Centerlock, 32 spoke QR. No Skewer included
$20 FSA Gossamer Compact Crankset- BBRight/BB30/BB79, 172.5BCD.
$20 Drive Side Sram S-Series carbon compact crank arm and spider. 172.5 ONLY DRIVE SIDE and SPIDER
$10 Pair of Origin-b Track drop out chain tensioners in black
$50 Shimano 105 mini group - FD-5800, 31.8 clamp, top pull front derailleur. RD 5800 long cage rear derailleur (surface scrapes, does not impact performance)
$10 Generic straight-blade steel track fork. Black, drilled for brake, approx 190mm of steerer
$10 Vittoria Zaffiro Pro 700x23 trainer tire in red
$10 Cyclops Power Trainer tire 700x23 with
$30 Scott MTB Shoes with mounted 2-bolt SPD cleats. Size 11.5US/46Euro. No smell, dirty but good condition
$30 Deda Zero100 Handlebars 31.7 clamp 43cm C-T-C. Tape residue, smudged badges structurally sound.
$80 OBO Unused, Uncut, Unmounted Fox 34 Performance Upper Assembly Unit. Black with rubberband/O-Ring. 34 Performance 160mm forks for 27.5” wheels. Damper, internals, lower casting, and axle are not included.
$30 Ambrosio G42 13 Volte Campione Del Mondo 42cm Gimondi Form Handlebar Cinelli. 26.4 clamp, 38 C-T-C wide. Shaped in Gimondi form, a little more rounded than the Merckx form
$40 Shimano XC90B 2-bolt shoes with Time cleats installed. SIze 10.5/45EU
$30 10-Speed H plus Son Archetype rims (grey color) to Mavic hubs with bladed spokes. Spokes have some surface rust and could use some scotch-brite to clean it off. The front wheel is true and rolls perfectly. The rear hub needs to be serviced and there is a spoke nipple pulling through the rim on the rear wheel. Not sure if it’s fixable but you can absolutely ride it with one less spoke. Wheels are sold as-is, buy the front wheen for $30, and get the rear free.
